Discuss Can you anyone tell me what fittings these are? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
1.5" solvent weld plastic comes through wall from kitchen sink and down into this.
Needs repiping due to bad joint. Would ideally like to pipe down as low as I can go without disturbing the bits actually in the floor but don't recognise the fittings below the coupler. Couldn't even feel certain it was plastic at the bottom just from looking and touching. What am I dealing with here?
Iron / steel pipe in the floor
Depends how brace you feel
Two options
Replace as existing converting from threaded to plastic via a female iron
Or
Option two undo the piece out of the tee and use a male iron straight into the tee
Ignore that second opinion
As it looks like they've broken / cut the steel pipe flush and jammed some 11/4 in :D
So only option is to dig down and fernco a joint on the horizontal steel pipe and replace in plastic
could try and cut the male thread in the tee from the inside and peel it away but that depends how solid it is
Cut it all out heat up the threaded stub and remove with stillsons, you can buy a 11/4BSP to 32mm solvent weld adaptor increase in size if needed to get you away from the iron swept tee then repipe as necessary . cheers kop
Reply to Can you anyone tell me what fittings these are? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
