Discuss Can't isolate radiator in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Sanjay Savani
    Sanjay Savani New Member
    I have a valve on the feed/return of the radiator and i cant shut it off. The trv end shuts off but all my radiators have this (as shown in pic) on the other side which i cant isolate with to change radiator. Help please do i need to drain the whole system to remove one radiator?
  2. Riley
    Riley Plumber GSR
    Is the part in your hand a cap
  3. Sanjay Savani
    Yes it tightens to the outside thread so that being on makes no difference just looks pretty.
  4. Riley
    Riley Plumber GSR
    Difficult to tell from the angle but is it an Allen key type slot?
  5. Sanjay Savani
    The inside is round so not allen key. And the outer nut thing wont turn on any of the rads.
  6. Riley
    Riley Plumber GSR
    The centre of the nut is round but is there a different shape below that in the cavity
  7. Sanjay Savani
    Not sure. It was a mates house he bought an i took that picture earlier today. I will check and see if it ia allenkey inside. I will get back to you on that one tomorrow. Thanks for the reply. Much appreciated
  8. Riley
    Riley Plumber GSR
    Pleasure
  9. Best
    Best Trusted Plumber
    Either a slotted screw or an Allen screw below the caps. Most likely Allen screw on modern LS valves that have no exterior spindle
    • Agree Agree x 1
  10. king of pipes
    As above needs to be shut off with the appropriate allen key count how many turns it takes to close . cheers kop
    • Agree Agree x 1
  11. fixitflav
    fixitflav Member
    I have Honeywell TRVs, > 20 years old. They're provided with isolating caps. You remove the TRV head, screw on the cap and it closes the plunger. I assume that gives complete closure, like an iso valve, but it's many years since I tried it. Whether more modern ones have this feature, or whether yours does, I don't know.
    But unless you can catch the water effectively, or there's nothing it can damage, you might be better off isolating all the other rads then draining the system remotely. That way there's only a small amount of water left in the rad. Also it's easier to catch the water from a drain fitting, so if you have inhibitor in the system you can return it when the job's done.
  12. scott_d
    scott_d Plumber GSR
    Looks like a danfoss LSV
    as above use an Allen key
  13. Sanjay Savani
    Yes it is a danfoss valve. Allen key shuts it off. Thanks all for the help. Much appreciated.
    • Like Like x 2
Loading...
Similar Threads - Can't isolate radiator Forum Date
Can't turn off central heating Central Heating Forum Sep 8, 2018
Kitchen mixer tap problem - can't disassemble... Plumbing Forum Jul 14, 2018
  1. cant isolate radiator
