Discuss Can't turn off central heating in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. barca
    barca New Member
    Dear forum
    My problem is I can only turn the central heating off and on by the main switch in the airing cupboard
    The program timer is Siemens RWB29 it all lights up I have just put in a new cell battery
    Or do I need a new HSA2 or could it be the thermostat sitting next to the programmer
    Any help would be good
  2. DGT plumbing
    DGT plumbing New Member
    What is you set up?
    Combi or traditional.
  3. barca
    barca New Member
    Sorry It’s a traditional
  4. townfanjon
    If you turn your room stat and cylinder stat down does it go off
  5. DGT plumbing
    Do you have a tree way valve ?
  6. DGT plumbing
    *three
    • Funny Funny x 1
  7. barca
    barca New Member
    No the thermostat doesn’t turn off and it’s a two way valve
  8. townfanjon
    Could you post some pics of your system, you would generally have 2 x 2 port valves
  9. barca
    barca New Member
    Sure I will do that in the morning
    I will take a photo of the 2x valves
  10. Ian10261
    Ian10261 Plumber GSR
    More than likely the 2 port is stuck open which means the microswitch inside is making the connection between the grey wire(permanent live) and the orange wire (switched live to the boiler).
    You may get away with taking the actuator head of and moving the valve spindle manually back and forth to free it up but this will more than likely be just a temporary fix. A new valve is the way to go and i would suggest a system flush while your at it, as dirty primary water could well be the cause of the valve sticking open.
    • Useful Useful x 1
  11. barca
    barca New Member
    Hope that helps
Loading...
Similar Threads - Can't turn central Forum Date
Kitchen mixer tap problem - can't disassemble... Plumbing Forum Jul 14, 2018
Worcester Heatslave II how to turn off DHW Oil and Solid Fuel Forum Saturday at 11:50 AM
