Discuss Central hearing not working but hot water is fine in combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
Just yesterday i turned the mains water off to work on the bathroom tap, i forgot to switch boiler off (not sure if this is what caused it) but now the central heating will not turn on at all on my Vaillant EcoTEC Pro 28 boiler.
Water has been heating up and working fine for the past day. There is no orange light to show that the water is being heated and the dial for the heating keeps turning and doesn't lock itself like before.
Just wondering if there is perhaps a simple solution to this?
Reply to Central hearing not working but hot water is fine in combi boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
My first thought when I heard this fault a combi boiler with hot water but no heating. Was a problem with the stat, controls not making the call for heat. If this is not the case. Can the divertor valve be the cause of the issue?
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
