Discuss Central Heating Fault, Motorised Valve? in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Skiny
    Skiny New Member
    Bit of an issue with my central heating this past few days, it's struggling to come on and was wondering if someone here could give me an idea of what's wrong.
    When I turn up the temperature to trigger the heating, it often seems to fail. It's hard to say how often, because it can work fine for a few minutes whilst testing, but then minutes/hours later, I'll try it again and it will fail.
    One of the valves is making a strange buzzing and clicking/tapping sound - I'm not sure if it's normal, but I'm guessing not?
    When it works, I will hear the click of the thermostat, then a whirring of the valve and then the boiler comes on. When it fails, I hear the click of the thermostat and then nothing at all after. Turning the thermostat on and off a few times will usually turn the heating on.
    The noise seems to be coming from the bottom unit, as you can hear in the video.
    If it's relevant:
    Boiler is a Worcester Greenstar 12i system boiler (showing 2 bar / just under)
    Thermostat is a 3rd generation Nest
    Unvented cylinder as part of the system
    Every single component in the entire system is just a few months old.
  2. ShaunCorbs
    Yea sounds like the syncron motor has gone
  3. king of pipes
    As shaun has said the motor in the zone valve is failing should be a free replacement if its only a few months old ? Cheers kop
  4. townfanjon
    townfanjon Trusted Plumber GSR
    As above ^^^
    , just under 2 bar . way too much , should be approx 1 bar when system is cold
  5. Best
    Best Trusted Plumber
    The toothed arm inside those Honeywell valves is sloppy and wears. They are poorly made IMO.
    You will hear a clicking sound and it will typically work intermittently for a few weeks or months, until failing totally
    • Agree Agree x 1
  6. Skiny
    Skiny New Member
    Thanks for the replies. I thought it might be the motor, I changed it earlier today. It's reliable now, in that it will turn on/off on command. However, the mechanism inside seems to operate slowly. Is this normal? Video below, you can just see the gold mechanism moving:
  7. Ric2013
    Ric2013 Plumber
    I think that's normal.
  8. ShaunCorbs
    Yep standard
    There made for toque not speed
  9. Chalked
    Chalked Plumber GSR
    Bit like me , these days!
Loading...
Similar Threads - Central Heating Fault Forum Date
Central heating header tank seems to be overflowing... Plumbing Forum Today at 6:30 PM
Flushing out central heating system Central Heating Forum Jul 29, 2018
