Discuss Central heating not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi we have a worcester bosch greenstar 30 i .Recently the c/h stopped working have tried thermostat but all that does is overheats the hot water.I have an idea it is the diverter valve ,What sort of price am I looking at for it to be fixed.
cheers
cheers
I'd make sure it's the part before contemplating the change of the diverter valve. How have you checked it.
Reply to Central heating not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
My daughter lives alone in a 3 bed semi in the west country. The house is 20 years old. The central heating and hot water are provided from a Glow-worm gas boiler working in conjunction with a Boilermate 2000. The central heating pipework is microbore. In view of the age of the boiler and...
Hi, I have a Worcester Bosch Greenstar 30Si combi boiler, the analog clock has stopped and the On-Timer-Off switch only works on Timer setting,. So I have set all the little timer switches to ON and the boiler does work then. Any help or source for a new clock would be great. TIA
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
  • Sticky
I thought I'd create a master thread to move all of these similar threads into, over time like. If your central heating doesn't work boiler doesn't work radiators not working radiators or heating system is cold thermostat wont work or respond Then post a reply in this thread. Rather than us...
1K
