Discuss Central Heating Pump Too Hot ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Just a quick question.
Should a Central heating pump be too hot at any time that you can't rest your hand on it for any length of time.
Cheers
Mark
Yes as your having 70/80 dc water flowing through
Normally they either work or they don't
Do all your rads work ?
If you are having problems with rads and the pumpmis red hot then no. But they will get reasonably hot in normal operation.
Everything is working, but the pump hunts when the central heating is on, and is noisier than normal (not an issue when just the hot water is switched on). I'm pretty certain there is no air in the system so I've ordered a new pump.
Just came across that page and thought this might confirm a dodgy pump. Though I did wonder how hot water could pass through the pump without the casing getting reasonably hot. I'll find out for sure when I replace it.
Cheers
Mark
Do you have one with an air bleed screw ?
Yes. I've bled this, but don't think any air was trapped. The rads heat to the top, so it appears to be just a pump issue.
The pump is about six years old and is a three speed model (Dab 55/130) that has always been set to the highest speed, don't know what is normal for the life span ?.
It's never run truly silent but is noticeably louder now, and the hunting makes the noise more annoying.
Mark
Do you have an old flat headed screwdriver?
If so with the pump on, undo the the bleed screw
And push your old screwdriver into the bleed port with moderate pressure does the pump stop ?
If it does pumps had it
No unless there's a major problem
You might get a drip or two but won't be much
I'll give it ago tonight. Just out of interest, is the distance between the inlets generally standardised. I've ordered an exact replacement to simplify fitting, but am curious if another make would have been a straight forward option.
Cheers
Mark
yes they are stnd
OK. Tested last night and there seems to be plenty of torque. I did notice that I can push the spindle back about 5 to 6mm. It returns immediately, so I assume the spindle floats or is sprung along its length.
One thing I did notice during the procedure. I let the system cool down by switching everything off and with the MV port in the CH position there was some heat (warmth) emitted from the MV housing. This is clearly coming from the electrics (motor/electro magnet?). To determine if this is normal I switched the MV into the HW position via the timer, turned everything off and half an hour later no heat.
It seems when the valve port is in the Central heating position, even with everything switched off, the motor/electro magnet? requires power and is generating some heat (nothing excessive). Is that normal?.
Mark
PS. The water from the bleed was not an issue, but more than a few drips. Half filled a paint roller tray after about 3 minutes.
Reply to Central Heating Pump Too Hot ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
So a strange conundrum regarding water temp if anyone can help resolve, would be much appreciated. Ive tried to give as much info as possible to give a full picture but let me know if ive missed anything. I have a Baxi Avanta 25h heat only boiler. Works fine. Unvented 300ltr megaflow. Stated...
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
  • Locked
Hi, I recently fitted a new central heating circuit and ran hot and cold to the bathroom and kitchen in my property (I was a CORGI registered central heating installer about 15 years ago, so I felt comfortable running the flow/return to rads). I am in need of a combi boiler install with a...
