Discuss Central Heating Quote in the Plumbing Jobs | The Job-board area at PlumbersForums.net
E
ek5943
Hi Guys,
I need some advise for a quote I have recently been given as I suspect it may be too high but wanted to check with people who know what they're talking about.
I recently moved into a 1920's style house and decided to get a service done on my boiler due to everything seeming pretty old, I suspected I may need some work done. When the engineer arrived it didn't take him long to notice some black marks on the pipes coming off the boiler to realise it was leaking carbon monoxide and consequently, he shut it down so I am left with no central heating.
After inspecting my torpedo water cylinder he advised it's probably too small for a house like mine (4 bedroom with a downstairs extension) and I would be better off with a megaflo unvented cylinder which could sit in my garage rather than in the airing cupboard upstairs. I was informed that my water pressure was currently too low (apparently it's pretty bad) for such a system but they could do some work from the water source in the street to increase the flow which should satisfy the new system.
The quote for said upgrades is 6k + VAT which includes a power flush and all new TRVs but this seems crazy expensive too me. I don't actually mind paying this amount if it was justified and I'm getting my moneys worth (I want to future proof my house so 6k over 25 years is fine IMO) but I want to check I'm not being taken advantage off. I also got a quote just for a boiler replacement with the existing cylinder and that was 3.3k + VAT which also seems expensive.
Any advise is greatly appreciated.
Thanks!
Tbh I think that's about right
New rads as well ??
New boiler
New unvented cylinder and move
Mag clean
New water main
Parts alone I think will be around 2.5-3.5k
What boiler has he quoted for ?
Not far off for london rates bud get him to break costs down if your worried good luck kop
Simple thing is to get another couple of quotes, cant give you any advise about price being that your in London (I'm Devon) but for what you are having done seems reasonable
I can only say, it's very reasonable for London E4. I work a lot in east London area and have seen different prices. But as mentioned you can collect some more quotes.
I tend to agree with most , it doesnt sound excessive to me, but agree area is a major factor.
Having recently had a new central heating. new electrics, full replaster etc I would simply say get at least 3 quotes for any major job.
You will probably find they all have different suggestions, different ideas on how to do things and wildly different ways of calculating rates.
I had quotes between 5500 and 8500 for my new boiler/rads install.
My full new electrics were quoted between 4000 and 6500.
I live in E4 , happy to pop bye to give you a quote
Warren
Reply to Central Heating Quote in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been facing central heating low pressure on unvented hot water RM Cylinders but can't see any leak on the PRV, expansion vessels and plasterboard celling. I have got unvented pressurized RM Cylinders hot water system with 27KW Worchester gas boiler with expansion vessels . When...
losing pressure
L
My central heating is run off a heat pump ( air to water ) quite expensive to run , So I’m plainning to fit a wood burning with a back boiler to connect to the heating system, So while the wood burning on during winter months it will stop the heat pump for working hard Or not all all . My...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always amazed at the water pressure so on the odd occasion that the water was only luke warm it was easily forgiven, but over time we have come to realise that...
M
Hello, We’ve recently moved into a fairly old, fairly big detached house (i.e. fairly draughty, but not too bad by any means) with a fairly new well maintained Worcester combi boiler. We weren’t convinced the heating was working right and then got hit with a £610 energy bill for the first 6...
MartinPod81
M
Can central heating / gas engineer expert help me with below issue. During winter time only, I have been having issue with low pressure or pressure dropping with unvented hot water cylinder system. During summer time there is no usage of central heating so the pressure at unvented system is not...
