Discuss Central Heating Radiator Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I need some help please. Just found a little leak on my radiator. Is it something I can attempt to repair or do I need to get a plumber? Thanks in advance.
https://i.*********/RJqFQox.jpg
Is it leaking out of the screw part?
Thanks for the prompt reply. That's correct, it's leaking from the screw part where it's rusty.
https://i.*********/SzKJpw5.jpg
Needs the drain off to be replaced
So the rad needs to come off
Upto you tbh but if you get a plumber out it shouldn't cost that much max 2 hours labour
Reply to Central Heating Radiator Leaking in the Plumbing Jobs | The Job-board area at PlumbersForums.net
