Discuss Change of old cistern parts in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Alfred Robinson
    Alfred Robinson New Member
    I have an old Armatige cistern (35 years old) with a 3/8" hole for the flush lever fitting, I wanted to upgrade to a flush king kit so In could change everything in the cistern but their lever shafts only fit the new 1/2" holes.
    Anyone know a new type flush system where the lever will fit in a 3/8" hole please?
    Alfie
  2. Last Plumber
    Last Plumber Plumber GSR Top Contributor!!
    Look at the Fluidmaster products. I know one has a button that sits on the outside but not sure on what else there is to be honest. Their products are as good a quality as you will get nowadays in my opinion.
    Try this link to the site
  3. Alfred Robinson
    My problem is the hole for the flush lever etc needs a 1/2" hole. Mine being old is 3/8"
  4. SimonG
    SimonG Trusted Plumber
    Drill it out to 1/2".
  5. Last Plumber
    The one I am talking about is 3/8"
  6. Alfred Robinson
    The hole is 3/8" in a ceramic cistern and I am afraid if I try to enlarge it to 1/2" the cistern may crack.
  7. steadyon
    steadyon Active Member
    If you use a diamond 1/2" hole saw and are very careful, using a template (which you can buy) to position it, you can drill ceramic with a low, but not non-existent, risk of cracking it. It's really a grinding process rather than a drilling process. Make sure you:
    1. Keep the drill well lubricated with water.
    2. Take it very gently, particularly at the start until it has made a groove.
    3. Check, before you start, that a 1/2" hole will not have its lower edge below the water line, nor its upper edge too close (10mm?) to the upper edge of the cistern.
  8. snowhead
    snowhead Well-Known Member
  9. Alfred Robinson
    yes I have that but I want to use the fluidmaster unit
  10. Alfred Robinson
    Sounds a bit risky. If I could just enlarge the existing 3/8" hole to 1/2" that would be great.
  11. Last Plumber
    The Fluid master Has a 3/8 " on some flush mechanisms !
  12. Alfred Robinson
    I phoned them and they said Kit 5 and 6 only in 1/2". Maybe the girl didn't understand but not in spec list.
  13. Last Plumber
    The one I have seen with 3/8 " was a push button which mounts on the outside.
  14. gpbeck
    gpbeck Member
    The Fluidmaster lever has a rubber washer which fits 1/2 inch and can be removed for a smaller lever hole.
  15. peter0504030201
    peter0504030201 New Member
    pictures would help please ?
Loading...
Similar Threads - Change cistern parts Forum Date
combi with stainless steel heat exchanger Central Heating Forum Yesterday at 7:03 AM
HEAT EXCHANGER IS STEEL MUCH BETTER boiler advice needed Central Heating Forum Thursday at 7:35 PM
