Discuss Changing cassette on Victoria Plumb Matrix tap in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. tomgrain
    tomgrain New Member
    I am having trouble removing the cassette on a victoria plumb matrix tap. you cannot use an adjustable spanner on the main body to remove, it requires some form of specialist tool to remove. There are 2 half round grooves in the main body approx 8mm. can anyone recommend where to get the right tool to remove the cassette?
  2. rpm
    rpm Trusted Plumber
    A picture always helps in these cases.
  3. tomgrain
    tomgrain New Member
    IMG_2774.JPG See photo
  4. Shower Engineer
    Shower Engineer Plumber
    Can you not get a socket onto that hexagonal nut?
  5. tomgrain
    tomgrain New Member
    Yep, but it won't undo the whole cassette. It looks like a specific tool is needed?
  6. Paulplumb
    Paulplumb Plumber GSR
    Can you not get the tool from Victoria plumb? If not could you pop a screwdriver into the slot and tap it round with a hammer until it loosens? Obviously you would do so at your own risk.
  7. Phil
    Phil Plumber
    They are disposable tat, even if you get the thing out victoria plumb wont help you. They will make you buy a whole new tap just to get the cartrige.
    You might get a univeral cartrige to fit off ebay.
  8. tomgrain
    tomgrain New Member
    Thanks for your help chaps. I will give it a go with a screwdriver and gently tap it round. I do have a replacement though I agree everything I have bought from VP is tat!
  9. rpm
    rpm Trusted Plumber
    I would try tapping it around, first on one side then on the other side and so on.
  10. tomgrain
    tomgrain New Member
    Will do. Thanks
Loading...
Similar Threads - Changing cassette Victoria Forum Date
Water Hammer Despite Changing Pressure Plumbing Forum Oct 23, 2017
Changing TRVs on a 10mm Microbore System Central Heating Forum Oct 11, 2017
