Discuss Choice of Pressure reducing valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Renovating bathroom just now and the wife wants mixer taps throughout. Normal single handle hobbj on the sink and a fancy traditional style beast on the bath.
Hot water is supplied from unvented cylinder at 2 bar closed pressure, 1.5 bar ish when flowing full tilt. Cold is supplied from mains at about 4 bar closed in.
I'll need to fit a pressure reducer on the cold side and I'm wondering if altecnic are any good as the y are significantly cheaper than Honeywell. I'm well aware of the adage you get what you pay for so illI pay for Honeywell if I have to, but I thought I'd at least check with the pros.
I'd guess I'd need to set it for roughly the operating pressure of the hot water system rather than the closed in.
Should I also fit a non return valve?
wheres the unvented cylinder in relation to the bathroom?
I would fit flow restrictors on the supplies to the taps or on the taps have a look on here . Cheers kop
Unvented is next door to the bathroom. Maybe about 3m of pipe between the bath and the taps.
KoP, I never thought of that! Bloody hellfire I'm a spoon. I've got a basin upstairs that spews water out the sink when the bairn opens the taps full tilt and it never occurred to me to fit them! A cracking point.
Also, save money cut carbon have some really good prices for stuff.
Why is there no balanced cold supply?
There usually is a draw off connection at combination valve (but some are different). Need a G3 unvented plumber to do any work related to the unvented unit.
All your taps should have had flow restricted by aerators in end of spout or flow regulators fitted in pipes to each tap. Madness to have full flow on every tap on high pressure plumbing
my thought exactly
The bathroom is 'downstream' of the hot water cylinder, the previous taps were all separate taps and the previous owner who had it installed had the mains go to those taps I'm guessing since the feed from the mains was there and it was easyea than doubling back the cold from the tank to the taps.
There is a balanced cold feed coming off the tank which goes to the upstairs bathroom.
I never really gave it much thought about the flow restrictors to the taps. We just never opened them up enough to cause a problem. Feel like a bit of an idiot now.
What qualifies as working on the cylinder to need a G3 certified plumber?
Any work on the unvented cylinder or the controls (plumbing and electric) generally needs to be done by a G3 plumber. Also includes most of the pipework including the discharge pipework.
So for example, a motorised valve supplied with unit is a safety component and you cannot touch that.
Same with an immersion heater, or any thermostat.
The pressure relief valves and combination (pressure reducing) valve also only a G3 plumber can work on.
But nothing to stop you working on hot and cold pipes in rest of house
Cheers best. I've been going by the rule that if it's close to the hot tank than the gate valves, I ain't touching it so sounds like I should be okay. I saw that episode of mythbusters! Same with the boiler. Too much electric on that for my liking.
So, I need flow reducers for the taps to get a sensible flow but will I also need pressure reducers as well since the bathroom has the cold off the mains?
Taking the balanced cold back from the hot water tank to the bathroom would be a bit of a nightmare at this point.
Or install new Pressure Reducing Valve, dial up type, set to just over 2.3 Bar on the incoming mains supply (ground floor).
Flow restriction stops splashing & saves water but will not stop possible cross-flow or poor tap mixing due to differential pressures.
Water Regulations require a check valve on both the hot & cold supply to any mixer tap or valve set because of the contamination risk.
You are right Koomber you genially get what you pay for RWC PRV's are good or better still a fully qualified Plumber with their Water Reg's & Un-vented ticket.
Honeywell are really the best and very expensive, I specify prvs for major manufacturing projects and thatā€™s the choice I make they are probably Ā£20+ to an end user. The Italian ones are cheaper and there are some that are Ā£5.00 in my world Pay up and buy American Also read the spec and if you are using large vols of water I think they have to be horizontal canā€™t remember
Reply to Choice of Pressure reducing valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. I need a new toilet supply line but donā€™t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic nut about the same size as the one going into the cistern but has a different thread. Attached is a photo. Can you advise. Thanks.
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
