Discuss Church install controls help! in the Commercial Plumbing Forum area at UKPlumbersForums.co.uk.
  1. harrygashull
    harrygashull GSR
    I have an install in a church, all fairly straight forward stuff however the client isnt keen on a proper bms system and VT circuits...
    Whats the worst case scenario if I dont fit vt circuits and a full bms system?
    I get the impression they simply cant afford the additional cost.
    They are also looking at UFCH next year so the VT circuits would likely be changed next year anyway.. so would be almost a temporary setup.
  2. ShaunCorbs
    How big of an install / system are we looking at
  3. harrygashull
    harrygashull GSR
    200Kw - 1 hw zone, 2 ch zones
  4. ShaunCorbs
    What boiler you looking at ?
    Also pump amp ratings?
  5. harrygashull
    harrygashull GSR
    5 x 40Cdi Classic Regulars
    1 x Grundfos MAGNA3 D 40-80F (0.2-1.2 A)
    1 x Grundfos MAGNA 3 D 32-40 (0.09 - 0.61 A)
    1 x Grundfos MAGNA 3 25-40 (0.09 - 0.46 A)
  6. ShaunCorbs
    Why 5 boilers ??? You do know you can get 100 plus kw boilers ?
    That's the part your going to struggle with
  7. harrygashull
    harrygashull GSR
    Yes I know, the problem is that they have 3 boilers currently all of which they let break down... cost prohibitive to get 3 reasonable quality commercial boilers...
    What makes you say 5 boilers will struggle?
  8. harrygashull
    harrygashull GSR
    Tried to push them to get three GB162’s but werent interested
  9. ShaunCorbs
    Because your going to need a 5 port sequencer for w and t also modulation
    Also at over 7.5kw for the boilers I'm sure you will be able to get two 120kw Viessmann 200 boilers for less even with rubbish terms
  10. harrygashull
    harrygashull GSR
    I know that!
    I know about the controls side of things, Iv already suggested this but like I say a full bms system is going to cost a lot which they are not keen on.
    Can I simply get them to sign a waiver?
  11. ShaunCorbs
    Sign a waiver to what the system won't work and boilers won't hand over / share the work
  12. harrygashull
    harrygashull GSR
    The system will work? Just in a very basic manner.
  13. harrygashull
    harrygashull GSR
    Im literally on about installing it in a domestic manner in a commercial enviroment
  14. ShaunCorbs
    Well it won't as there's too many boilers one or two will have the most load / working time on them
  15. ShaunCorbs
    Which won't work
    If you want to keep it simple install one or two boilers
    One for the heating load and another just for hot water
    Are you commercially qualified?
Loading...
Similar Threads - Church install controls Forum Date
Advice for heating system to install Central Heating Forum Thursday at 9:23 PM
Questions about installing a thermostat for traditional boiler Plumbing Forum Jun 21, 2018
