Discuss Clipping pipes under kitchen sink in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. Gossamer
    Gossamer New Member
    Afternoon,
    First post here so please go easy..
    I'm fitting a kithen (DIYer) and wondering if it is ok to clip 15mm copper pipe to the hardboard backing under the kitchen sink. I'd like to bring the pipes up through the bottom of the unit and have a nice layout on the backing board to serve H+C taps and the dishwasher.
    The backing board seems a bit flimsy but what other options are there?
    Cheers.
  2. ShaunCorbs
    Yes but it will need some bracing at the back of the clips
  3. Gossamer
    Gossamer New Member
    Cheers - do you mean attach some ply behind the backer? Or a baton across where I want to run some clips?
    There is space as there's a 70mm service void.
    • Like Like x 1
  4. ShaunCorbs
    Either would be fine
  5. Gossamer
    Gossamer New Member
    Is there an alternative?
    I suppose what I'm asking is what is the conventional way of doing it?
    I've seem people clip to the wall behind and cut out a 'window' to connect the flexi's etc.
  6. ShaunCorbs
    Half the time they don't clip them
    Depends on where the pipes are I normally clip behind the unit to give maximum space inside the units
  7. Gossamer
    Gossamer New Member
    I think im overhtinking this. Reckon I'll come through the backing, right turn, connect the valves then attach the flexi's directly. Stealth..
  8. ShaunCorbs
    Don't forget some ISO valves if you have space
  9. ShaunCorbs
    One I did last year
  10. Gossamer
    Gossamer New Member
    Thanks.
    Very thankful you posted this as the kitchen is fed from above so I'll need drain offs. Had slipped my mind.
    Whats that little oval bit? Behind the panel?
  11. johnduffell
    johnduffell Member
    looks like the main incoming stop cock and drain off (plus equipotential bonding)
    • Like Like x 1
  12. ShaunCorbs
    spot on
Loading...
Similar Threads - Clipping pipes under Forum Date
Drilling near a shower - how to avoid pipes Plumbing Forum Sep 12, 2018
Boiler questions: pipes and purpose Plumbing Forum Sep 8, 2018
  1. forum fitting pipes under kitchen sink
