Discuss Clogged toilet/tub explanation in the Plumbing Forum area at UKPlumbersForums.co.uk.
Tags:
  1. Susspence
    Susspence New Member
    If I could please get a quick explanation about what is going on with my toilet/tub I would really appreciate it.
    Toilet is clogged. Tried for a while to plunge it. It has resulted in nothing other than my bath tub now being backed up. Why is this happening?
  2. Matchless.plumb
    Matchless.plumb Trusted Plumber
    Hi and welcome,
    Perhaps the main soilstack is clogged and therefore nothing will drain but backing up. It's happening because there is a blockage which is caused perhaps due to too much use of toilet paper, woman waste,baby wipes or anything similar.
    • Agree Agree x 1
  3. Best
    Best Trusted Plumber Top Contributor!!
    As above reply says, - some part of your sewer pipe is totally blocked and it has backed up with water. Wipes are notorious for causing blockages.
    If you live on a ground floor/bungalow then it will back up sooner.
    It may just be a simple matter of needing some excess points on stack or the manholes opened and the underground sewer rodded by someone capable.
    Or ring a local company who clear sewer blockages and ask first their charges.
    • Like Like x 1
  4. king of pipes
    You need a drain company to attend and clear the blockage and jet the drain run . kop
    • Agree Agree x 2
  5. ShaunCorbs
    dyno rod fixed fee £90 will clear most blockages
  6. Matchless.plumb
    But not on weekends , it will be easily 120-140
  7. Angelo1960
    Angelo1960 New Member
    The following could be the reasons if your toilet isn’t flushing its contents all the way:
    -The poor toilet drain pipe design.
    -A clog in the toilet, flange or drain.
    -The water level in your toilet tank is set too low.
    -Blocked inlet holes.
    -Problems with your flapper.
    I think it's better to call a plumbing service to get this fixed. It's not just gross, but it's wasteful and annoying when your toilet doesn’t fully empty its contents when you flush. So, rather than 'DIY-ing' get the help of a professional as soon as possible.
    The following could be the reasons, if your toilet isn’t flushing all the way:
    You can also refer this blog Easy Steps To Fix A Clogged Toilet Without A Plunger | Brothers Plumbing Company for easy steps to fix a clogged toilet without a plunger.
  8. rpm
    rpm Trusted Plumber
    Welcome Angelo, do you Canadians always say things twice? o_O :)
    • Funny Funny x 2
  9. Angelo1960
    I got lost in between :p
Loading...
Similar Threads - Clogged toilet explanation Forum Date
Cannot find toilet seats with 270mm gap between hinges? Plumbing Forum Feb 11, 2018
Another toilet bodge Plumbing Forum Feb 3, 2018
