Discuss Closed Coupled gasket - seal . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
quality
Hi Toilet are not m thing as some may know however I have replaced a fill valve on cistern whilst carrying out other work at a property and the gasket between the flush mechanism and the pan is a little tired. It measure approx 70mm id but all the ones I can seal are for a 1 1/2 thread which is not big enough thanks in advance
Is it like a big o ring ?
That not the same one but I am pretty sure it will do the job thanks
Looks like a stnd donut with a hex in the flat end ?
You could do with a 2" foam doughnut! - what I always use, you can pick them up from your local City Plumbing
Big thick 2" foam doughnut with a nice bead of plumbers gold, will seal superbly, dont envy who goes in afterwards though!
Reply to Closed Coupled gasket - seal . in the Plumbing Jobs | The Job-board area at PlumbersForums.net
