Discuss Cold water storage size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there,
Looking at running a single shower (no other demand at all).
Want to use a 1.2 bar shower pump and feed a normal small shower head. Nothing to big.
Have 162 litre hot water tank and a 227 litre cold water storage tank.
Will this be big enough on the cold water storage side?
Thanks!
Yes you will be fine need both supply's connecting to the pump and an s flange fitting for the hot and a dedicated supply from the cold tank
Hi there,
Thanks!
do you actually know what type of pump you really need ?
Reply to Cold water storage size in the Plumbing Jobs | The Job-board area at PlumbersForums.net
IS IT POSSIBLE TO ADJUST THIS MIXER UNIT? WE HAVE TO HAVE IT TURNED ALMOST FULLY ANTI CLOCKWISE TO GET HOT WATEROUT. THE FRONT PLATE WITH MIRA ON IT PRISES OFF AND INSIDE THERE ARE SOME PLASTIC BITS AND A SMALL CROSS-HEAD SCREW IN THE MIDDLE. THANKS
