Discuss Cold water tank almost boiling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I would say your neighbour will still need a high limit stat fitted. Which activates their heating pump to come on if their fire is overheating.
Reactions: Cat
HA are going to connect downstairs neighbour to gas & install a gas central heating system
No more tank in our attic
Cat
Spot the difference...
Replaced tank until neighbours get new gas heating system installed.
Cat
Am I missing something where's the connection and vent ? :D
I though that. It Looks like it is piped into the side of the tank? However I wouldn’t say that was an adequate support would you @ShaunCorbs ??
Reactions: Cat
Oh guys....what now?
Is that not looking like it should?
There was I thinking it was way better than that auld warped wee plastic tank...
Cat
Can you get a pic of the other side where the pipes attach please. If it is possible.
Reactions: Cat
Metal tank does not need to be fully supported underneath. Full support regulations only apply to plastic tanks.
Reactions: Cat
How is the vent pipe done in that tank?
Pipe insulation needed.
Not a complaint - and perfectly acceptable, but seems plumbers have to use solder elbows because they can't use a bending machine to do more than one square bend on each piece of pipe. :)
Even if that is true. Would you have left it like that?
If I had installed it, no, that's messy and why not centre it on the hatch is beyond me. But I wouldn't call it unsafe. Assuming the loft hatch is fixed in some way, and even if not then it's probably okay from a technical perspective.
Whats a bending machine?
It's a long pole which you bend the pipe around, having filled the pipe with a bending spring. Saves strain on your knees. Often has wires or a lamp attached to the top to make it look like a lamp-post or telegraph/electrical pole.
unless the pole decides its had enough and falls over :D
Reply to Cold water tank almost boiling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
