- Messages
- 1,030
Well done Cat, power of the press and some professional advice from this forum = ***RESULT*** sleepless nights for you (bliss)!
Discuss Cold water tank almost boiling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I though that. It Looks like it is piped into the side of the tank? However I wouldn’t say that was an adequate support would you @ShaunCorbs ??
It is the old hatch lid!!!It could well be.
Even if that is true. Would you have left it like that?Metal tank does not need to be fully supported underneath. Full support regulations only apply to plastic tanks.
Thank you. It looks like You have all pipes that you need we just couldn’t see them all.
If I had installed it, no, that's messy and why not centre it on the hatch is beyond me. But I wouldn't call it unsafe. Assuming the loft hatch is fixed in some way, and even if not then it's probably okay from a technical perspective.Even if that is true. Would you have left it like that?
Am I missing something where's the connection and vent ?
Whats a bending machine?How is the vent pipe done in that tank?
Pipe insulation needed.
Not a complaint - and perfectly acceptable, but seems plumbers have to use solder elbows because they can't use a bending machine to do more than one square bend on each piece of pipe.
It's a long pole which you bend the pipe around, having filled the pipe with a bending spring. Saves strain on your knees. Often has wires or a lamp attached to the top to make it look like a lamp-post or telegraph/electrical pole.Whats a bending machine?
Do you still flare pipe??An old bloke. Not many left anymore.
Reply to Cold water tank almost boiling in the Plumbing Jobs | The Job-board area at PlumbersForums.net
