Discuss Combi boiler, hot water but no heating in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Tyrone Edwards
    Tyrone Edwards New Member
    i have an Ideal Espirit 2 boiler, the water is working perfect but the heating is not working.
    We had a new pump fitted about 12 months ago, I've had three tradesman in and they have all said sometime different; one said I needed a new pump the other said I needed a new programmer and the third said I needed a new boiler.
    I'm sick of being ripped off, can someone please let me know if they have any idea what the problem could be
    Thank you
    • Like Like x 1
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    What do you mean by not working. Can you please supply more information.
    • Like Like x 1
  3. ShaunCorbs
    Ideal have a fixed price repair, if your stuck
    • Like Like x 1
  4. Tyrone Edwards
    As mentioned the water is working fine, the thermostat is bluetooth, the pump does not even fire up
    • Like Like x 1
  5. Tyrone Edwards
    I do know before we had the pump replaced, the iprogrammer got wet, the digits still show up so I assumed this to be fine
    Could this be the issue?
    • Like Like x 1
  6. Harvest Fields
    What programmer is it?
    • Like Like x 1
  7. Tyrone Edwards
    It's the Esprit 2 35w - itime programmer
    • Like Like x 1
  8. jtsplumbing
    jtsplumbing Plumber GSR
    Is boiler showing any fault code ?
    • Like Like x 1
  9. Tyrone Edwards
    There's not fault code showing
    • Like Like x 1
  10. jtsplumbing
    Well as its working for hot water that means your Pump is OK, these did have problems with the control panel, but other things need to be checked on heating side not allowed to go into to much detail ! what did the other people check when they looked at your boiler ??
    • Like Like x 1
  11. Harvest Fields
    Random question but your thermostat is turned up isn't it?:p:p:p;);):)
    • Like Like x 1
  12. Tyrone Edwards
    I’m not sure what was checked, other than three different options, I’ve purchased a new control panel which should be here Monday, if that doesn’t fix it then I’ll replace the bluetooth thermostat.
    • Like Like x 1
  13. Tyrone Edwards
    I knew there was something I didn’t do
    I’ve bought a new control panel which I’ll fit Monday and see what happens.
    I’ll post the results
    • Like Like x 1
  14. dan_the_plumber
    dan_the_plumber GSR
    Sounds like external controls at fault. Simple test is to pull message wires out and put a link in. If programmer/stat at fault, your boiler should now run constantly on a heating demand
    • Like Like x 1
  15. ShaunCorbs
    FYI you need to be gas safe ;)
    • Like Like x 1
Loading...
Similar Threads - Combi boiler water Forum Date
Cold water tank in a flat with a combination boiler?? Plumbing Forum Jul 8, 2018
using a pump with a combi boiler Plumbing Forum Jul 3, 2018
  1. new combi bolier fitted hot water ok heating not working
  2. combie boiler hot water but no heating
