Discuss Combi Boiler Housing Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi there
We are getting a Valiant ecotec 831 fitted. It is replacing the last valiant ecotec we had previously. It was fitted on the outside of the external wall of our kitchen and housed in a box that the plumber built out of plywood (see attached photo). Does anyone know if there is a commercially available unit, preferably made from something more weather resistant, that we can buy to house the combo boiler?
Thanks!
Yes there is but I would be seriously questioning his ability if he left you like that / thought that was ok
Hi Shaun,
It is a different plumber doing the fitting. What is the unit that you are thinking of?
Hi Shaun,
Electrical ip65 panel
Hi Shaun
The Electrical ip65 panel looks the part. Any ideas where I could get hold of one quick sharpish in London?
Hi Shaun
That's a tough one as normally built to order your best bet would be talk to your gas fitter (how much clearance he needs round the boiler ) this sets your size for your enclosure
Then go to a local sparky merchant (better if they do commercial stuff) and see if they have anything / can get you
Hi there
Thanks!
This is a wind up right?
No - why?
The person fitting the boiler outside will need to come up with a solution that meets;
Gas regs.
Electrical regs
Building regs.
Manufacturers instructions.
And doesn't invalidate the warranty.
I doubt the original enclosure would have met any of the above.
From the M.I's;
Observe the following when choosing the installation site
and operating the boiler,
– Do not install the boiler
in rooms prone to frost.
Would you do that shaun? theres always a alternative mi s state internal use only you would have a hard job getting them to stand by the warranty . kop
Yes and already done one was a Worcester and they said fine must be ip rated have an external first stat and pipes lagged
Still up and running now :D
We have done loads of external boilers around my way as they were all solid fuel but always in a brick built extension type of enclosure. I did query this a few years back .
We have had no trouble at all
Reply to Combi Boiler Housing Question in the Plumbing Jobs | The Job-board area at PlumbersForums.net
