Discuss Combi boiler left dormant for 3 years. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
macackau
Got a job booked for tomorrow to re-instate a combi that hasn't been used for 3 years. It has been left full of water. I'm thinking to flush system through with fresh water and then follow MI commissioning and servicing instructions. Any other advice?
What manu is it
I did similar a month or so back with a Ferroli, ended up changing every "O" ring and washer on the boiler
If you know the make and model, may help to get some washers etc beforehand
Thanks for the replies. Unsure of make and model, good point about the o-rings, if I get a feeling it's going to need them replaced then I'll order them up before doing any work on it. Wouldn't be surprised if pump has siezed.
I'd check the exp vessel also, probably will have lost its charge.
Pump and fan will be the things that will more than likely need attention. Definitely give it a flush through once its all heating up and then some inhibitors after.
Reply to Combi boiler left dormant for 3 years. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
