Discuss Combi losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi
I have a Combi boiler that keeps losing pressure. I top up, up to 1.5, but this drops within 6 hours and the system switches off.
We have looked everywhere and cannot see a leak. I have used the Fernox F4 leak sealer, but this hasn't helped.
Any ideas?
(Yes I have had a Gas Safe Engineer out before you post that)
Hi
Any ideas?
Then I would get him back out. As it is clearly not fixed and you have looked at the external parts of the system. It maybe within the boiler? Is the copper pipe outside dripping?
No, no problems with the pressure release
He suggested the leak seal, so I've tried that. Was just looking for advise before getting him back out.
What boiler?
Top up the pressure
Turn off the power to the boiler
Shut the flow and return valves
If the boiler looses pressure it's the boiler
If the system looses pressure it's the system.
please can you offer me some advice. I have a greenstar 37CDi boiler losing pressure. I charged to 1.5 barg and closed flow and return 90 degree boiler valves to shut position. Overnight the pressure had dropped to zero by the morning. I have already fitted a new expansion vessel and checked bladder pressure is still OK with no water on bladder side. I have left a container under the pressure relief valve and observed no water over 24 hrs leaking from it. Any other ideas for me to check?
im not gas registered, this id my own boiler. I thought i had a leaking pipes but not sure now after checking the boiler last night.
I would get a Gas Safe in mate. You shouldn’t be taking the case off your boiler.
Yes - no playing with the boiler or its controls please. I had a couple of slow leaks that were in the CH plastic distribution pipes to ground floor rads at home. The rising connection to the rad was copper but there was a transition to plastic (90 deg elbow) in the concrete. Weep weep, ho hum. My first step was to put in valves to isolate the rads one at a time and locate the leak.
hi,
Greenstar 37CDi boiler.
Pressure relief valve is dry but i have noticed a constant steam of water from the condensate pipe. Any ideas what has failed in the boiler?
hi,
Even when the boilers off ?
Well the Electrician thinks the heat exchanger may have a pin hole :)
Hi Shaun,
Yes even with CH not running. If I top up pressure to 1 bar then water starts to flow out of condensate pipe.
If you tell him that he should sort it / give you advice on your options
Reply to Combi losing pressure in the Plumbing Jobs | The Job-board area at PlumbersForums.net
