Discuss Combi sudden pressure loss. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, my 80 year old mum has a combi boiler that suddenly loses pressure. She lives 70 miles away and having problem diagnosing fault. It happens irregularly and suddenly so dont think it is leak. Expansion tank and prv has been changed by a local plumber. I think it might be dumping water out the prv, but never when i am there and have left tub under prv but it rained, tied freezer bag to prv, it split (could have filled and split).
Any ideas, I am thinking intermitant pump fault or thermostat causing system to overheat and dump pressure?
Any ideas welcome, this only happens about once or twice a week.
I am a qualified gas engineer but I mainly do site work so not experienced in fault finding.
Thanks.
When the expansion vessel was replaced was the pipe connecting it checked? I've had instances where the connection at the boiler end has been blocked. Might be worth a look.
I have removed this and blown through it etc, but thanks for your idea. I did wonder if dirt in system could be intermitantly causing such blocking.
It would certainly help, Rich, if someone could monitor what the pressure is doing as the boiler heats up - that would be a good indication.
But I understand your mum would find this difficult.
What make and model of combi is it? (Not that I'm thinking that'll help...!)
Really needs a gas safe engineer to take a look guys not something for the DIYer to be guessing at
Rich , if you are GS , email admin with your number .
Otherwise its against the rules to encourage somebody to remove a boiler case
Apparently have to post 10 times, I'm gas safe messaged Lou and Dan with GS number and card serial number, no response.
Thanks for your replies.
I have checked pressure when visiting and behaves normal going from 1 bar cold to about 1.75 when hot.
Sorry did not mean to break any rules. I am gas qualified and registered through the company I work for. Dont do private jobs just new build installation. The work already done was by a local firm to my mum but they have failed to sort it and was just looking for suggestions before shelling out more money. I work for Cook and Harris Ltd reg no 1942
The boiler is an Ariston eco combi 27 mffi and is about 14 years old. Mum was charged about ÂŁ800 to fit expansion vessel, if I new it was going to be that much I would have advised new boiler
Robbing gits !!
Hi Rich
It was a sealed system Ariston that I had to drill the crap out of the block where the flexible pipe connected, not that seems to be the case with yours.
Hi Rich
Thanks Neil. I do wonder if it might be the pathway to expansion gets temporarily blocked. Might try fitting external expansion vessel as there is room in cupboard.
You rang town ?
sorted
Reply to Combi sudden pressure loss. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Conditions: nearly 10 year old boiler WB2B, heating mode off, DHW on or also in standby, Boiler shows no fault LED on, no new fault logged, room thermostat deactivated. Boiler gets odd attacks of suddenly turning on the fan 100%, then (gas valve and ignition are clicking?) potentially tries to...
Got up on Wednesday morning no hot water, (only cold water coming out of hot tap). Checked boiler, it had zero pressure and F1 fault showing. So I refilled the pressure using the filling loop, up to about 1bar which is where it usually is, which worked fine, had hot water all day. Same thing...
1K
I'll pop this into the general advice forum as it seems the most active, but mods - feel free to move if there's somewhere more appropriate. Thank you! --- Apologies, but yet another "boiler losing pressure" thread - I've read many others, but am no closer... Not my boiler (parents), so...
2K
  • Locked
Looking for some help here - not my boiler, so consider me a proxy. I'm also by no means a heating engineer: I'm just looking for pointers, as the owner of this boiler is now caught firmly between "not us", "not us" and "not us" - nobody will take responsibility, and just calls into question...
Good Afternoon all, I am hopeful someone may be able to offer some guidance on the following. In the home we have a gas boiler (serviced annually, October time) providing hot water to the CH system which is split into 3 zones (Honeywell 2-way valves) and it also heats the HW tank (Tribune...
