Discuss combustion analysis on space heaters. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bob12
Hi i'm currently on placement and my engineer's analyser is being re-calibrated and I don't have have any others readings to go of. So if some one could tell me what area of CO,CO2, CO/CO2 and O2 reading you get on balanced flue gas fires. Thanks
Hello bob12,
I doubt very much whether you will get that information on here !
Your question will seem to be asking for information that could be used to falsify Gas Inspection / Gas Appliance Commissioning Certificates !
Also Gas Safety specific questions will only be replied to if the Member has proven to the Forum Moderators [Gas Safe registration etc.] that they are Gas Safe registered - they then get a `GS` badge showing that they are Gas Safe registered.
Even if You do submit Gas Safe registration details you are still asking for Combustion information - which because you have stated that your Combustion Analyser is away for calibration - will seem to be for the purposes of falsifying either a Gas Safety or Gas Appliance Commissioning Certificate - entering `readings` that you have not taken !
If You are supposed to be using a Combustion Analyser on the Appliances that you mentioned you must know that to produce documentation with false `readings` for those appliances / ANY appliance because you do not have a Combustion Analyser to use is potentially VERY DANGEROUS and definitely ILLEGAL !
I await replies from other Members / a Moderator.
Chris
Hi bob what are the readings going to be used for ?
And normally with balanced flue fires just old school it
Hello again bob12,
I was not suggesting that You would use the ratios that you asked about to falsify any Gas Appliance documentation.
Having since seen Member Shaun`s reply to you I did think when writing my previous message to ask you what you wanted the figures for - BUT - I thought that Members & Moderators would `jump all over both of Us` while stating something similar to what I wrote above !
I hope that You will take my message in the way that it was intended - to explain why We could not supply the information that you asked for in an `Open Forum` - as there could easily be other readers / non Gas Safe people who would use the figures for the wrong purposes.
Chris
Hello again bob12,
Chris
Your posts hurt eyes, any chance of one colour and one font?
Hi CHRISX and Shaun
The reading would be used on a placement form not any kind of gas safe certificates. I was tolled by my placement engineer that it was unnecessary on the fire we we'er servicing because it did not say to in the M.I's. But my assessor says I need it for the form even if the M.I's say not to, and if I can not get them I will have to throw this one out.
`Hello rpm,
I don`t know why you have decided to post a comment about my occasional use of coloured text / coloured paragraphs.
As You know - I do that to highlight comments that I believe are especially pertinent to the thread / message that I am responding to.
I am unaware of any Font changes - I do not alter the Font between paragraphs in messages that I write on here.
Are You an argumentative person who tries to instigate conflict between Members ?
To answer your question:
"No I will not confine myself to just `one colour` / the default text black / dark highlights".
Chris
You don't need to do a fga on a fire, just
Flame picture
Gas rate
Burner pressure etc
I would be thinking twice if the collage contradict the manufacturer instructions
But you can use these
0.0002
6.8
18
They were from a set of 3 rinnai gas fires, not that they will take much notice I think :)
Hello again bob12,
Thanks for replying / answering Shaun`s question about why you wanted the Combustion Ratio`s.
It is strange that an Assessor has told you that you need these figures when the Gas Fire in question does not require the Combustion process to be tested using a Combustion Analyser.
Chris
Hello again bob12,
Chris
I'm guessing it's a stnd worksheet the collage uses and they need every box filled ;)
MESSAGE DELETED BY CHRIS - MY PREVIOUS MESSAGE TO MEMBER RPM WHICH HAD DISAPPEARED HAS REAPPEARED.
I think you are correct they may just want it all filled in. Even if its not needed o_O .
And thank you for the info I can continue with the rest of my forms now:).
I did portfolio 2 years ago. Went through a college. They said to show CPA on appliances where MI'S don't ask because it shows understanding of 7967 the readings obtained.
Hope this helps
Reply to combustion analysis on space heaters. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Had our gas Baxi Combi inspected and serviced today, as it has been every year. Gas safety cert issued and says all okay, but engineer gave what I think was very... ambiguous... advice. 12yo boiler with the following readings on the analyser printout: O2% = 4.1 CO ppm = 192 CO2% = 9.5 Ratio =...
Good morning all, just a quick one here and i was wondering if someone could give a little advice on their own experience. I don't usually do a lot of installs or a tremendous amount of gas work but obviously when I do undertake these things then I try my best to keep within the appropriate...
hi, I am after some advice, I recently fitted a new gas valve to a vaillant ecotec earlier. the boiler was fitted in 2015 and has been serviced since anyway I put my analyser in the combustion side of the flue and the readings were extremely high, something along the lines of CO ppm —OR—...
2K
Size of bathroom 230cm x 210cm Height 230cm Birmingham Area Initial problem Burst pipe underground in bathroom, concrete. Have had this dug up & made safe for now, have had affected pipe cut & put end caps on. Work required Full bathroom remove old tiles walls and floor. Renew tiling. New...
E
I reckon if I did a survey of 100 heating engineers, asking what would they recommend for heating a granny annexe being built onto the side of my house, in place of the garage, most would give me a suggestion to put in a) an extension to the existing boiler rad circuit & electric water heaters...
eco-heating options
E
