Discuss Commercial cooker requirements in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have a customer who would like a normal domestic gas oven/ hob installed in a pub, the kitchen it will be used in is not for commercial use (only to be used by the tenant in flat). Would this still be classed as a commercial installation? And would it still require an inlet of air, currently it only has mechanical extraction.
If it's not in the pub Kitchen and like it's in a annex / room above the pub
Your fine with domestic cooker qualification
It is in the pub kitchen but they don't serve food
I would say yes you need to be comcats then, but phone has safe up and see what they say
If it's a domestic appliance, i.e. not a commercial catering appliance AND the gas system at the property falls within the scope of IGEM/UP/1B then you can do this on a domestic ticket, no issue there as far as I see.
Unless I'm wrong in which case I'd be grateful for a reference to a regulation that says I am!! Would like to learn from it if I am.
You will still need a openable window or door to outside or a fixed open vent to provide supply air ventillation.
Reply to Commercial cooker requirements in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I’d like to replace gas cooker. Curry’s do install but I know they will refuse to install if regs are not met. So I want to understand whether the proposed location is acceptable to qualified gas safe fitter. I can’t find official, definitive list of regs anywhere. Can you point me to...
  • Locked
Hi, A little about the business: I currently own a plumbing business (website and marketing) - looking to target residential and commercial market (i.e. tendering to main contractors flats etc). My background is a commercial manager, I use to do plumbing years back so technically I would not...
I have tried hard to get similar to the first class satchwqell /Sunvic SML type revolving type valves instead of the quite short lived spring return type valves. I saw an advert from the Hearken company who either make these or buy them in. The only problem they are BSP threads so adaptors are...
Hi We are a commercial premises Have been using the same plumber for years and very happy with his work but recently came to light he has a domestic ticket. When questioned he said it was ok as all the boilers he works on are under 70kw? He also says he does not touch the commercial catering...
1K
I have a open flue old boiler (natural draft for combustion) installed on outside wall. Before winters want to install a heat only condensing boiler (room sealed), cannot install it at the current location as it is open to weather effects (rain and sun light in summers). I cannot install it in...
