Discuss Commercial FGA in the Plumbing Jobs | The Job-board area at PlumbersForums.net
cr0ft
Hi all,
Starting to do some commercial boiler servicing at work. For direct and indirect boilers/water heaters including domestic what's the best FGA to look at??
330ll2 (testo) i have
Upgraded from the 327 both are very good for commercial
Forgive my ignorance on this, will the Testo do domestic and commercial boilers??
Also, what about creating certificates etc or printouts for them. Does it make that easy?
What's good about them??
Yes they will do either Domestic or Commercial
I like em because they are reliable, easy to use, good quality etc.
Print outs, yes it comes with a RF printer.
I use it all the time, on Industrial, Commercial and domestic Gas and Oil burners/Boilers. Had one for 15 years and this one about 4 or 5 I think.
None of that rubbish like you have with the Kane's then, 90s purge before you can use it??
Croft.
You may already have done this but if you look on Testo site you can Hire equipment if you are unsure or want to try it. I think it might be one of those try before you buy idea's
It might be worth it before a big spend
Thanks LP, will do that. It's a lot of money to spend and I can try it out on a couple of our boilers first that way.
Bss will hire them out or get the testo rep out
They seem to use Kane at the assessment centre I use but I never
If I were you I would buy that 327 they have on at the mo at just over £500. It will do all you need and last for years.
The £99 per year service they offer is not a bad deal. I didn't take that out and it has probably worked out cheaper but only by chance I think.
Where do you guy's purchase your Testo FGA's from?
Sick of paying way over the odds over here for testing equipment.
Just bought some CO detectors and gas detectors from the States at @ 50% what the same items cost here.
Battery operated, so no need for voltage concern.
Can't wait to show the Rep who tried to sell me the items at double the cost.
Where did you buy it from mate?
Reply to Commercial FGA in the Plumbing Jobs | The Job-board area at PlumbersForums.net
