Discuss commercial pictures ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
how dya do that then
Open it in pic viewer rotate it left save pic then rotate it back right and save
Can do I guild if you want ?
any more pics why
any update?
Its all been finished now, will try and get a picture when the plant rooms cleared out and painted
have you got any pics showing flow pipework from the boilers into the system,
St Peters 1.jpgJust started This one 3 ACV Prestige 120kw on cascade.
Looks good Ch4, neat pipe and frame work.
How come there is no expansion bellows on the pumps? Are the copper lines below the pumps the returns?
I cant quite make out whats what, guessing the 54 or 67 at the bottom is flow from boiler?
Be careful with the prestige, Chris. The condense traps have a tendency to drop off.
Mind you, it might be more the older models.
Its not the only problem ive had John, the cascade kit was thrown together and had to remake the lever valves onto it to get them level!
From top, Cylinder Flow - Return, Heat battery Flow - Return, Expansion Vessel feed, Heating Flow And yes the Bottom pipe is the Heating Return, 76mm on the Primary's.
Its as per the Mechanical Drawings with the exception its now turned on its side due to the plant room height.
Looking good
You ever had a look inside?
Looking good
Hi Shaun,
Only a burner service this time round, burner off and stripped down with its massive individual pilot, checked the run of the mill stuff and shined a torch down to check the quarl bricks you can see in photo 3 them glowing nicely - insurance inspection will be a full strip down and climb inside!
Love the big stuff - il put some process pictures up later of working on some interesting burners!
Round about 1mw ?
Would love to work on something that sized but there coming far and few between
Comtherm burners on bread baking plant - easy to maintain but the linkage kits (in the 2nd photo) are a nightmare to set up - a Honeywell servo motor on left hand side.
Commercial kitchen shoehorned into a tiny first floor room! Then they wondered why there were vent problems :)
Fun and games dropping this onto a hospital roof at crack of sparrow!
Guy building a nuclear bunker near here. Does he know something we don't?
New posts
Reply to commercial pictures ? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Show us your fanciest radiators you've installed! We would love to see them! I love this Milano vertical radiator in the kitchen space. What do you think?
