Discuss Concealed basin waste (false wall) in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Neil Davenport
    Neil Davenport New Member
    Hi all,
    i am renovating a shower room and intend for all the pipework to be concealed behind a false wall.The basin will be in the middle of a 3 meter wall and the waste will need to run horizontally to the corner of the room.the connector i will be using in the wall for the trap is shown below:
    [​IMG]
    Is it best practise to have a short vertical drop after this before the horizontal run or can the waste pipe go horizontal immediately( allowing for the appropriate fall?
    Any advise appreciated
    Neil
  2. ShaunCorbs
    Either is acceptable just make sure it's supported depending on run I normally do one clip per two feet (24")
  3. Neil Davenport
    Thank you for the reply/advice, much appreciated
    Neil
Loading...
Similar Threads - Concealed basin waste Forum Date
semi-concealed in ground gas box Gas Safe Registered Plumbers Only Jul 23, 2018
Concealed Cistern - help with changing flush valve Plumbing Forum Jul 13, 2018
