Discuss Concealed Cistern - help with changing flush valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys
Firstly...go easy on me! I’m a site basher, I’ve installed loads of Concealed cisterns but never had to fix one! I’m venturing into the world of domestic maintenance and it’s nerve wracking!
So is it really possible to change a flush valve through the hole where the flush plate is?!
I had a look at one today and it needs replacing, Cistern is behind fully tiled boxing.
It doesn’t seem possible I can get it out the hole, but then it must do right? Otherwise what do I do?
Thanks!
yes normally do you know the brand?
Not too sure. I’ve attached a photo of that helps!
Thanks so much!
And I can get that out through the hole? I don’t need access to the rest of the Cistern.
dont have a clue i would try taking the old one out it should fit but cant be 100% as ive never seen that type fully built in
Twist it the wrong way and you might break the securing lugs :(
Reply to Concealed Cistern - help with changing flush valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
Hello, we were misadvised on how much a Lusso Stone cistern could be cut down (by both the architects and Lusso). The bathroom has been plumbed / tiled / had boxing out built and it is now apparent that the Lusso cistern is too high. We are urgently looking for a concealed cistern that is...
Hello, I have to replace the flush valve and/or the washer but unfortunately it's inside the vanity unit. The only way is removing the toilet. I turned the screw on the cistern pipe to stop the water. I removed all the silicon around the toilet, now I can easily lift up the Front panel but...
I have a Geberit concealed cistern . This has a dual pneumatic flush, and has worked without any problems for a few years now. The short flush continues to work normally but the longer (6 litre) flush no longer flushes fully which results in solid waste not being flushed. I have checked the...
1K
Hello, I want to change the system fill valve, but I’m struggling to dismantle the existing toilet to access underneath the tank, I’ve added some pictures can anyone advise of the steps? Thanks!
Hi all Relatively inexperienced homeowner here. Apologies in advance if I get any terminology wrong. Today I noticed some limescale accumulation on/around the grout between the floor tiles next to my toilet. I realised that the grout line right next to the toilet was in fact wet to the touch...
1K
