Discuss Concealed shower valve in the Bathrooms, Showers and Wetrooms area at UKPlumbersForums.co.uk.
  1. Kus
    Kus New Member
    Fitting a Pure concealed shower valve with 3/4 female inlets and outlets. Would you recommend 3/4 male to 22mm connectors or 3/4 to 15mm? Running off a unvented tank so have reasonable pressures.
  2. ShaunCorbs
    What shower heads are being installed?
  3. Kus
    Kus New Member
    Large round shower head and a separate hand held shower arm
  4. ShaunCorbs
    22mm as far as you can then down to 15mm
  5. Kus
    Kus New Member
    It’s only a 2.5 m run to airing cupboard where the hot and cold pipes come out in 22mm so could stay on 22mm pipe. Would I be able to tee off the pipes to the shower to supply the bath and basin.
  6. ShaunCorbs
    yes but 22mm straight from cylinder don't use plastic pipe as it reduces the pipe dia
    You getting a pro in to do the work
  7. Kus
    Kus New Member
    Yes getting quotes in now
Loading...
Similar Threads - Concealed shower valve Forum Date
Whats best technique for concealed shower wastes Bathrooms, Showers and Wetrooms Oct 13, 2018
concealed mixer, what brands to choose Bathrooms, Showers and Wetrooms Oct 12, 2018
