Discuss Condensate pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Deleted member 2053
What is the vote as to the quietest condensate pump? I have a customer who has just bought a house with an ageing Grundfos unit in the bedroom cupboard and is complaining of being woken in the night.
Thanks guys
It's in bedroom I'm sure it could be piped up to work with out pump for say ÂŁ600
Reply to Condensate pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, my Mothers heating failed in the recent UK cold snap. I found the pump was stuck. I have a question about pump orientation. The existing pump flows downwards. The manual for the proposed replacement recommends that it should pump upwards. This would involve rearranging the flow &...
Central Heating Pump - G Pump Force HE-RS25/6PWM-130 Hi, I would be grateful if someone could explain whether our CH system can cope with the AUTO (adaptive mode) setting on this the new pump or which mode it is best set at (recently had our old 3-speed pump replaced with the above smart...
Hi, I am replacing our 11 year old boiler (due to H.Ex. leak) with a new one. This is in a "sealed" system with red expansion vessel in airig cupboard & a megaflo (no tank in loft). However the exisiting boiler is Vaillant ecoTEC 4xx boiler - which is satated by vaillant as an "open vent" boiler...
Hi all, I have an old Combi boiler for which the heating has stopped working. The hot water is fine, and I think I've isolated the problem to the pump. The pump is a Grundfos Alpha2, and it has usually has two numbers, but it is instead showing two dashes ( -- ). I think the propeller isn't...
Our boiler is in the loft and I encountered a leak in a roof above our side extension store room which has transpired to be from the boiler condensate pipe. It was cracked at an elbow so the plumber we use has replaced this and hopefully all will be well with that joint. This later prompted me...
