Discuss Condensing Boiler Flue Discharge in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. Martyn2
    Martyn2 New Member
    I have recently had a Worcester Bosch 30Si boiler installed and it works a treat. However I have noticed that when it is fired up, in addition to the plume there is a steady drip of water that comes from the flue (externally not internally). Is this normal because I thought all the condensed water went down the drain via a pipe.
  2. Harvest Fields
    Harvest Fields Trusted Plumber GSR Top Contributor!!
    Can we have a picture of the flue terminal please and the angle it exits the wall.
  3. ShaunCorbs
    No it's not right sounds like there isn't any fall on the flue
  4. Harvest Fields
    Agree mate but wanted to see a pic before I made my mind up:p
    • Agree Agree x 1
  5. townfanjon
    Odd drip ok , steady drip no .
    • Like Like x 1
  6. hammers4spanner
    hammers4spanner Plumber GSR
    I thought the fall was built in the flue on the inner duct ?
    I think sometimes the fan can blow a small discharge outside ,also on some moisture does collect on the lip on the black terminal.
    • Like Like x 1
  7. Harvest Fields
    It is but if it is a short length and bad angle they can drip.
  8. hammers4spanner
    I forgot to mention they are also crap which is possibly why its dripping
    • Friendly Friendly x 1
  9. ShaunCorbs
    No I don't think Worcesters are
  10. scott_d
    scott_d Plumber GSR Top Contributor!!
    Always cranks the angle up as you tighten the flue flange
  11. Harvest Fields
    Not your favourite then mate?
  12. Harvest Fields
    Thought they were?
  13. hammers4spanner
    No got one in my own home worst boiler ever had
    • Funny Funny x 1
  14. Harvest Fields
    That’s why I recommend Vaillant’s. But will still fit Worcester if it’s what the customer wants.
  15. Rob Foster
    Rob Foster Top Contributor!!
    Vaillant has been a good boiler for years, I had the first sign written vaillant vans in Bath in 1987 ish complete with Easter bunnies on the back.
    • Informative Informative x 1
Loading...
Similar Threads - Condensing Boiler Flue Forum Date
Weather Compensator - Greenstar CDi condensing boiler Central Heating Forum Sep 5, 2018
Condensing Boilers - what volume of codensate is discharged Central Heating Forum Aug 7, 2018
