Discuss Condensing Boiler Flue Discharge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have recently had a Worcester Bosch 30Si boiler installed and it works a treat. However I have noticed that when it is fired up, in addition to the plume there is a steady drip of water that comes from the flue (externally not internally). Is this normal because I thought all the condensed water went down the drain via a pipe.
Can we have a picture of the flue terminal please and the angle it exits the wall.
No it's not right sounds like there isn't any fall on the flue
I thought the fall was built in the flue on the inner duct ?
I think sometimes the fan can blow a small discharge outside ,also on some moisture does collect on the lip on the black terminal.
No I don't think Worcesters are
Flue is pointing downwards so incorrect angle / fall I would say
Reply to Condensing Boiler Flue Discharge in the Plumbing Jobs | The Job-board area at PlumbersForums.net
