Discuss Connecting a macerator in line with Bath/Sink/Shower waste pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
Gavin1210
Hi looking for some advice if this is possible?
Existing waste pipe from bath/sink/shower is 40mm tapped into a cast iron vent pipe.
Gavin
Welcome to the forums Gavin, are you saying the outlet pipe from the macerator is tapped in to the soil stack?, what problem are you having?
See from another forum this is a project job. Are you sure the pipe is the soil stack? And I`ll be interested in which make and model of pump you are thinking of using with a 40mm discharge.
Thanks.
Hi rpm, still to fit the macerator. Wondering if I can tap into the existing waste pipe in the bathroom or do I need to run a separate waste to stack which is quite some distance away. Would back flow be an issue?
Hi, so you have 1 bathroom therefore the existing waste pipe must run to the stack, are you planning an en-suite in another room on the same floor? Sorry not getting the full picture at the moment.
I'm extending what was a shower room with sink in the upper floor of a challi style bungalow to incorporate a toilet and a bath. The existing waste from the shower/sink connects into a cast vent pipe some 4m from the room. I was hoping to tap into the waste from the shower/sink to prevent running an additional pipe from the macerator to the venture pipe.
Reply to Connecting a macerator in line with Bath/Sink/Shower waste pipe in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello. I am planning to build a small half bath in my garage, next to a washing machine, using old showers plumbing. There was a stand-alone shower in the garage which has been removed. Unfortunately the pipes are only 1.5" on that side of the house since there's no bathroom and the house is...
I am installing a sink in utility room. Washing machine waste already exists and is the verical pipe with the flexib pipe from the machine poked down the top and a with a u bend at the bottow going directly to outside drain. Is it OK to put a tee joint into the verical pipe and join the sink...
Hello hello,, Hoping there are some experts or experienced Bulgarian plumbing chaps in this site ?. Here in the UK I can fit a bathroom just with the experience I have picked up over a lifetime. I can make copper pipe runs isolaters taps sink shower etc but me and the missus have bought a small...
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can recommend? Maybe with some appropriate tape. The waste pipe is in the wall but was trimmed at some point (unnecessarily) to only 10mm extruding from...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
