Discuss Connecting pure water flexi tap connector to 3/8" John Guest in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Grateful for any help on this problem.
I have a Harvey's water filter running a John Guest 3/8" outlet pipe.
I need to connect this to my 3 way tap, which has a flexi tap connector (male) which has an 11mm thread (approx).
Thinking I had this sussed, I ordered a 3/8" x 7/16" UNS tap connector but this didn't twist on to the thread.
I purchased the tap from eBay, which was made in China.
Any ideas on what tap connector will fit/I need?
Thanks in advance.
Made in China you may very well struggle I’m afraid. Maybe take the tap into a local plumbers merchant
Dunno it’s guess work without seeing it it could be metric compared to imperial it could be a random foreign measurement.
I've spoken to the seller and he said it's a standard UK size - 8mm, 1/4" connector. Given the 7/16" was too small, surely the 1/4" will be even smaller?
What am I missing?!
I ordered the 3/8" to 1/2" connector but the female end is massive.
I've attached an image of the pipe - any help would be appreciated.
The thread shown above is not formed properly.
Take it out and take it to the merchant as advised because there is no point whatsoever in guessing with something that badly machined.
If its Chinese, then it will supposedly be either a BSP, NPT or metric thread. If it's NPT then only 1/2" & 3/4" is compatible with BSP. If its metric, there is some overlap with BSP. Please do as suggested.
The other end is attached to the tap, so now difficult to take out to show a merchant.
The 3 way tap has 3 flexible hoses attached. The other two (connected to the water softener are now connected)
The advice still stands if you wish to do it properly and properly is all we can advise here.
Reply to Connecting pure water flexi tap connector to 3/8" John Guest in the Plumbing Jobs | The Job-board area at PlumbersForums.net
