Discuss connecting to outside main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
chelsea
got to connect up to old steel pipe, it looks like 3/4 pipe to me.
what is the best option to connect to? copper? plastic?
any help would be great
its being buried too
Replace with MDPE , Confirm steel with magnet. Lead will scratch easily. If lead, use lead lock as coupling. If steel, best to find threaded coupling but take care when uncoupling not to unscrew any part of pipework you wish to retain.
its deffo steel, mdpe conects to the steel pipe? or do i need to get an iron to fit?
If you can find a joint remove and use a male or female iron or cut pipe and use a philmac trans coupling
Reply to connecting to outside main in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have decided to remove the timber floor boards and joists as they are effected by damp and rotting. Was hoping to infill and have slab and screed floor. There is a gas servile pipe under the floor which enters the property below the joists at the front of the house and comes up under the...
Got a replacement combination boiler, less that 1 year old. Noticed some water from the connection pictured. Can't see what is it from the manuals, possibly a rainwater drain? Was told by the person from Vaillant that it was an A A V (auto air vent), but she didn't sound too certain! Can...
Hi I have a question, I want my flat to be separately connected to the mains water supply for water coming into my kitchen and bathroom instead of sharing the same pipework as my neighbours. Is this doable and if so is it the water board who will carry this out or a plumber? My flat has shared...
Hello everyone. New to the forum and looking for assistance / advice. I live in a rented house with a not very co-operative landlord. I have just discovered that my bath overflow drain pipe is not connected as the flexible drain tube looks like it has been cut off at some point. After studying...
I have a cold mains in that is a black flexible rubber looking pipe. Please see photo 1. It is currently connected to a 22mm stopcock. I’d like to send it 90 deg to the right. This is so I can lower the shelf above it and have the mains come in at a more convenient place. See photo 2 (with...
