Discuss Connecting waste from two sinks and a dishwasher to wall in one piece? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Thanks in advance for any help...
I need to put in a waste pipe(s) as follows; two sinks next to each other with male threaded 40mm outs, one rubber waste pipe from a dishwasher. So three waste pipes. They need to connect to one waste pipe which is hidden in the wall. The waste pipe in the wall has a 50mm female weld type connector protruding to be able to connect to, and it has been placed in the wall so that the flange to connect to is too high, it is lower than the waste pipe connectors from the sinks, but only just, about 5cm, so if I connect a waste trap to the sinks the output from the waste trap is then lower than the connector of the wall waste pipe so there is always water trapped in the pipe between the trap and wall, which I don't like. I'm an amateur and all my constructions leak at some point. Does anyone know if there is a manifold or some such piece which exists will allow me to connect the three outs to the wall in as few pieces as possible, ideally one pre-fabricated piece, so that there are no joins to leak from? Doesn't need to have a trap if it can't be done without the water level dropping below the wall waste pipe opening.
Is it the top, centre or bottom of the waste pipe that is 'about 5cm' lower?
How deep are the sinks? You might be able to find shallower one(s) that will make the problem go away.
Have you considered repositioning the waste in the wall a few inches lower?
Given the 2 statements above, I think you'd be better off employing a Professional.
It'll be cheaper and quicker in the long run.
Thanks rpm, looks better than the stuff I have, I think the main problem for the leaks actually lies with using cheap material, the seals here look much more substantial than the ones I am using.
Reply to Connecting waste from two sinks and a dishwasher to wall in one piece? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, grateful for any advice I need to connect a dishwasher waste water outflow pipe 25mm to 50mm waste pipe. Is there a joining piece anyone can recommend? Maybe with some appropriate tape. The waste pipe is in the wall but was trimmed at some point (unnecessarily) to only 10mm extruding from...
    • Useful
My parents have a leak from kitchen sink. My dad removed waste trap and since refitted it leaks, but there wasn’t any kind of seal on it, I got a rubber/plastic gasket that seems To fit the trap but with it, I can’t get it to screw and lock back on (has lugs so locks after quarter turn. But...
Hi all, I have a couple of leaks coming under shower tray downstairs. One is along the wall so think might be joint between wall and tray and the other seems to be near waste tray, there is a slight hairline crack in shower tray near waste . This happens when I leave the shower head near the...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
Think I know the answer is no but asking just in case. I have a solvent weld bathroom waste with lots of connectors in it that disappears into the wall with a right angle connector. There is no place to break into it to connect up a new arrangement for a new sink. So does anyone make a...
