Discuss Constant dripping from outside pipe in the Fittings & Pipes area at UKPlumbersForums.co.uk.
  1. Paulandbecca
    Paulandbecca New Member
    Hi. Anyone know why I have constant dripping from the outside pipe. Been like this for a while now.
    It’s like a curve shape.
    Combo boiler is in the loft.
  2. ShaunCorbs
    Do you know what the pressure is
    Also any pics of the boiler from inside?
  3. Paulandbecca
    Just taken below pics.
  4. ShaunCorbs
    Would say you need a gas safe engy to sort the problem out
    • Agree Agree x 1
  5. Paulandbecca
    Would you happen to know what the problem could be?
  6. townfanjon
    townfanjon Trusted Plumber GSR
    Yes , but you need the boiler case off and you have to be GS regested to remove it
    • Agree Agree x 1
  7. ShaunCorbs
    Spot on
    And yes I have an idea
    • Agree Agree x 1
  8. Paulandbecca
    Googled it, few people saying pressure release valve. I’ll get pics of the inside
  9. ShaunCorbs
    Inside what ?
  10. king of pipes
    You need a Gsi to repair this paul, the expansion vessel has failed dont go pulling it apart nothing you can do bud . cheers kop
  11. townfanjon
    There was not much point me replying to your post was there .
    • Agree Agree x 3
    • Like Like x 1
  12. Riley
    Riley Plumber GSR
    Not grasping this not going in the boiler bit are you
    • Like Like x 1
    • Agree Agree x 1
    • Funny Funny x 1
  13. king of pipes
    My opinion for what its worth you have to give the op something or we come across as arrogant and unhelpful, ruels still apply though, boilers with a casing that needs to be fitted and are part of the combustion, our posters may not be aware of this so thats why we treat them all the same and advise not to remove the casing and contact a GSI . Cheers kop
  14. Harvest Fields
    Harvest Fields Trusted Plumber GSR
    Technically there should be an inside case also on that boiler if I remember correctly. However the PRV is a safety device and should not be messed with by somebody not qualified to do so. I have no idea why people come on here and ask for professional advise and then when it’s not what they expect they ignore all responses as if they hadn’t asked in the first place. This website should have a function to instantly delete posts from people with no common sense, not just lock the posts.
    Edit due to spelling mistake
    • Agree Agree x 1
Loading...
Similar Threads - Constant dripping outside Forum Date
WB Greenstar 37cdi fan runs constantly Central Heating Forum Yesterday at 10:47 PM
