Discuss Continues running boiler ... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
hello guys,
A customer called me and asked to come over it to solve the problem with his procombi boiler... never heard or seen those boilers.
Apparently vokera makes them but don’t put their names ...
When he turns hot water on boiler fires but when he turns it off it still runs continuously... has anyone an idea what to do or to look for as I want to be a little prepared ...
Regards
Ron
The Ideal Procombi has a pre heat setting so would continue to fire
for a period after tap turned off.
If it continues to fire and only goes off on overheat then there is a
problem.
problem.
Thanks a lot for the help, it’s much appreciated.
I found the fault, there is a massive leak on the hot water pipe and that’s why the boiler keeps firing because it’s thinks he’s uses hot water. He lives at the groundfloor and therefore he did not notice any leak. He has got a water rushing sound even when the boiler is turned off. Ones you turn the boiler on it automatically starts firing even though taps are closed. Hot water pipe is getting hot.
Reply to Continues running boiler ... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
W.B Greenstar 4000 installed. Heating not turned on yet as not cold enough here. But the boiler runs every day at 0933 (hear it fire and hear water in rads). Rad water runs for literally 3/4 seconds. Stops. Does it again a couple of seconds later. Then nothing until exactly at 0933 the next...
Hi all, I have a wallstar combi oil fired boiler. We got low on oil a couple of weeks ago but didn't run out. Since we've had our oil delivered the boiler won't fire up when hot taps are turned on so no hot water. The boiler fires up periodically to heat water but not when we turn on taps. I...
I have a 23 year old Megaflo heating and hot water system powered by the original Thermecon oil boiler. One of the most common kinds of faults I get with this system is the continually running circulating pump. The upstairs and downstairs CH are separate circuits each with their own Danfoss...
Deleted member 120897
Any advice welcome as plumber stumped Had 36-46 grant vortex utility boiler 7 years no problem recently oil tank move and tigerloop install (tank about 1m lower). 10 days later and boiler either doesn't fire or fires stops, fires runs splutters stops. Most it runs now is 10 mins, but that's...
Hi, I have just moved into a house that has a Worcester oil fired boiler, when powered up it burns constantly even when the heat setting is off and no hot water running, is this normal ?? Don’t know how old it is and waiting documents to be returned from the Soliciters to see what service...
