Discuss ContractorForum: Schluter Kerdi Shower System: We have one to do soon, and it made me in the Plumbing Jobs | The Job-board area at PlumbersForums.net
- Status
Administrator
Staff member
Admin
- Status
Reply to ContractorForum: Schluter Kerdi Shower System: We have one to do soon, and it made me in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone. I'm installing a walk in shower, opening into shower will be on right, mixer value on right, but shower head and drain on left.
The pipe work from the shower mixer valve is exposed silver colour pipework. the pipe work will run up from the valve then take a hard left at the ceiling...
Hello there,
Relatively recently we had a new en-suite fitted (complete rip out of the old fittings, and old wall tiles and floor carpet). This consisted of a quadrant shower enclosure, a stone-resin shower tray, new ceramic tiles on the floor and half tiling on the walls. All the work...
Hi everyone,
I moved into a new build three bedroom, two bathroom bungalow about 2.5 years ago. Ever since we moved in there has been an issue with the water pressure.
Toward the end of last year the pressure had got worse. For instance, you could not run another tap in the house if a...
Hi - recognise this a bit of an odd one. We have an old failed mixer valve which we need to replace. This valve actually predates a temperature controlled boiler, so the mixing functionality is irrelevant, since the cold water pipe is isolated/off.
I'd ideally like to replace the shower valve...
We live in a 1980s four-bedroom detached house. The time has come for new central heating.
The current system is a mild revision of the original heating installed when the house was built, and this revision was largely to replace a life-expired boiler:
non-condensing fan flue boiler
open...
