  1. Checkout our Plumbers Insurance area - heavily discounted Public Lability Insurance and Van Insurance specifically designed for plumbers.
Discuss Conventional boiler - Water is not hot enough in the Central Heating Forum area at UKPlumbersForums.co.uk.
  1. DaniQ
    DaniQ New Member
    I moved in a house with a Vaillant Thermocompact 620e boiler with an insulated hot water cylinder.
    The heating works OK but the water for the bath and taps doesn't get hot enough. I have the hot water "wheel" turned to the maximum and i get water at 35C after having the boiler on for 4 hours
    Is there any way to increase the temperature to something like 50C?
    Thank you.
  2. ShaunCorbs
    What does the cylinder stat read ?
  3. DaniQ
    DaniQ New Member
  4. jtsplumbing
    jtsplumbing Plumber GSR Top Contributor!!
    What temp is boilerr stat set to ? what is cylinder stat set to ? could be a number of things , Fault with boiler stat, or something else with boiler, Faulty cylinder stat, or 3 way valve faulty,
  5. ShaunCorbs
    The box with the white band around the cylinder
    What's that set to
  6. DaniQ
    DaniQ New Member
    Is the boiler stat the grey thing on the left of the cylinder or the white smaller box attached to the cylinder?
  7. DaniQ
    DaniQ New Member
  8. ShaunCorbs
    That should be on 60
    And no that's the port valve grey box with 3 pipes connected
    Pic of your boiler with the flap down please
  9. DaniQ
    DaniQ New Member
    1502124403013.jpg Which position the 3 way valve should be set to? W M H?
  10. Stigster
    Stigster Plumber
    You don't set that. That's an indicator to show what position the valve is in at any given time. Water/Mid position (both on)/Heating. It's open to the hot water side in that pic.
  11. clemda1
    clemda1 GSR
    Could be one of three things? 1) the programmer, 2) cylinder stat or 3) 3 port valve. Simple tests you can do:
    Set cylinder stat to 60deg
    Set programmer to hot water only
    Confirm the boiler fires (assuming the pumps is working ok as you said the heating is ok)
    Now on the diverted valve feel the pipe going to the cylinder (cylinder flow pipe) this should pretty soon star getting very hot ( to hot to touch) and should stay hot until the cylinder reaches temperature (60eg)
    If not report back as to what in the above sequence did not happen and we can help further.
Loading...
Similar Threads - Conventional boiler Water Forum Date
Greenstar 40cdi conventional Gas Safe Registered Plumbers Only Dec 7, 2017
Worcester Bosch Greenstar (conventional) Not Firing Central Heating Forum Nov 4, 2017
