Discuss Cost of fitting a new kitchen sink. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys, Hope this post is appropriate, if not I will remove immediately. Just had a new kitchen fitted by the Housing Association. Unfortunately, the sink that was fitted isn't very good. It's stainless steel, but the basin side seems to be untreated and dull, and after a few days has marked badly. The draining board is still shiny but it's warped ie: if you push down on it, it clunks and then clunks again when you let go. Anyway, I digress...I'm going to buy a new one and was wondering how much it would cost to be fitted? (ballpark). I've included a pic of basin and pipework. On a side note, I wanted one of those black composite sinks, but have read that they're easily marked and hard to keep clean. Should I stick to the SS sinks? Thanks, Adam :)
I would say under £100 if you supply everything eg new sink taps etc
Put it on My Builder or similar web site and somebody will do it for £20.;)
Thanks. Yes have just been looking at My Builder. Although don't think I could pay someone as little as £20 lol. Bit wary of sites like that. Had a bad experience with a tiler from there. I'm sure I was just unlucky though. Thanks again :)
Reactions: rpm
Reply to Cost of fitting a new kitchen sink. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello I'm going around in circles trying to find a new kitchen sink. We want a white one, ideally a more modern look like granite or composite than ceramic. When reading about Franke and peers composite sinks I read a lot of reviews suggesting they feel cheap and plasticky. So... 1) What...
Hi everyone, I want to purchase the following filter to put under my kitchen sink but am not sure if it will be able to fit the copper pipes as they may be too narrow for the fit. Any advice would be appreciated...
  • Locked
Just looking for some advice, I have just fitted a new kitchen sink and both water pressures are the same in hot and cold on the mixer tap, both connected to tap flexies with shut off valves, however when hot is turned on it is not turning on the hot water for the boiler, previous sink had...
1K
Hello I am fitting a kitchen in a new room without services. Looking to tile the floor so everything under the tiles really needs to be fit and forget. Looking for best advice on fitting drainage for the sink and dishwasher please. Photos of situation below. Sink will be under window and...
1K
Had to replace my kitchen sink waste strainer and have struggled to find a direct replacement. The old fitting is plastic with a screw on top to tighten to the sink. The length is 60mm with a 45mm thread diameter which screws into existing pipework. I shopped around and managed to source a new...
1K
