Discuss Customer emailed, wants plastic bath panel replaced with 'wooden one.' in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
What would you use/do?
Bog standard mdf white one don't forget to seal edges if you have to cut it , or I have used tounge an grooved green mdf also
If local then pop in and measure it yourself just to be certain on the size and there are / used to be some which were easy to cut down to size.
I usually fit the wooden 2 piece panels that you set to size your self, less than £100 for side and end usually
Reply to Customer emailed, wants plastic bath panel replaced with 'wooden one.' in the Plumbing Jobs | The Job-board area at PlumbersForums.net
OFFICIAL SPONSORS
OFFICIAL SPONSORS
