Discuss Cutting off 110mm solvent weld elbow qustion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
plumbduff
Hi
I need some advice please
The soil pipe elbow exits to low for a new pan at only 150mm centre height - it should be about 185mm
If I cut/saw the soil pipe elbow off will the internal diameter left be sufficiently wide enough to accommodate the flexible pan connector shown?
I think it will be but I don't want to burn my bridges by doing it without prior advice.
Thanks for your help
I posted a thread sometime ago about this and the consensus was that it was solvent not push fit, it does seem well stuck and now i can get to it I see there is no clearance around the pipe for a rubber grommet seal so I'm confident its solvent.
It will have a suitable ID for the flexi to work but the stack is push fit can't you swop the spigot branch for a socket all round one & do it properly instead?
Beat me to it again Simon
PS it is push fit not solvent weld
Thanks for confirming that
Removing the elbow:
I have pushed a thin palate knife around the edge of the joint to shift the hard deposits gumming it on.
There is a bit of twisting and lateral movement which seems to indicate it is push fit, but it is very stiff.
I don't want to damage anything by trying pull it off using brute force although I have it supported.
(not sure how robust it is)
Is there any kind of release agent I could squirt in to aid removal, which will not perish the rubber seal?
Also maybe a little heat
It`s been there for awhile so don`t expect it to just easily pop off and No to using heat !!!
Help! YUK?
Managed to remove elbow only to find a can of worms.
How do i get rid of that?
It's solid rope - dental floss, rags god knows with calcium layer underneath sticking it down
tried tugging hard as poss - but its well and truly stuck
Any suggestions? call dyno rod
Help! YUK?
Carrier bag and pull if you can't shift it yes call dyno rod
It's out "nono"!
I prised it out using a flat curved wrecking bar to release from the calcium holding it down.
It was like a 6ft long putrefied ferret - carrier bag! it filled a bin liner.
Nightmare over, elbow off and ferret gone.
It's out "nono"!
If you can pour a bucket of water down it to see if it's clear
And isn't plumbing fun :)
Caution:- Pan connector fits internal diameter of 110mm pipe not ID of collar. Necessary to insert short length of pipe in collar before pan connector.
Reply to Cutting off 110mm solvent weld elbow qustion in the Plumbing Jobs | The Job-board area at PlumbersForums.net
