Discuss CWSC overflow dripping in the Plumbing Forum area at UKPlumbersForums.co.uk.
  1. Dan1706
    Dan1706 New Member
    Any help here would be appreciated. My overflow pipe from the CWSC in the loft is dripping. It is not a constant drip. I have regualry been checking the level in the loft but is never at the level of the overflow pipe. I am confused as to how this is happening.
    Is there any other reasons for why a drip can occur?
  2. ShaunCorbs
    How old is the ball valve ?
  3. Dan1706
    Dan1706 New Member
    I would say very old. The cistern is the open type with just insulation covering the top.
  4. ShaunCorbs
    I would change that as a first port of call could be that dripping at night when the mains water pressure is at the most
  5. Dan1706
    Dan1706 New Member
    Ok, thanks for that. I will do that first and see what happens.
  6. rpm
    rpm Trusted Plumber Top Contributor!!
    Is there a 22mm copper pipe that comes up, over and drops back down towards the tank?
Loading...
Similar Threads - CWSC overflow dripping Forum Date
Header overflow - should be so simple. Plumbing Forum Sep 7, 2018
Trouble removing plug release/ overflow cover. Plumbing Forum Sep 4, 2018
