Discuss Danfos TP9000 issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hello, I recently moved into new flat fitted with danfoss tp9000 programmable thermostat for both central heating and domestic hot water. Issue is my heating and hot water both seem to be working all time even though I have programmed on off events in tp9000. The tp9000 indicator light comes on and off as per my timed events but regardless of that my boiler (unvented indirect water boiler) seems to be working all time being controlled by its own thermostat. My understanding is that the boiler thermostat should operate only during the hot water On event in tp9000. Any clues as to what might be broken? The tp9000 is wall mounted and main power supplied without any remote sensor.
Thx in advance for help.
Rented ?
I would say time to call a pro out
The chances are that the problem is not with the programmer or the
boiler.
What is the make and model of your boiler?
Do you know what type of heating system do you have?
Does your system have 2 port/ 3 port valves probably in or around
the airing cupboard?
boiler.
Boiler: Range Tribune HE Indirect Unvented Hot water cylinder (manufactured by kingspan)
Central District Heating system (hydronic)
Separate zone valves for central heating (1-zone) and domestic hot water
2 port valve
Thx
The Range Tribune HE Indirect Unvented Hot water cylinder is not a boiler.
It would be best for you to get a heating technician in to check out your
system.
The problem likely to be to do with the zone valves but could be something else.
Reply to Danfos TP9000 issues in the Plumbing Jobs | The Job-board area at PlumbersForums.net
