Discuss Danfoss Actuator help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi please could someone tell me if it’s possible
I have got a danfoss HPA2 actuator which is not working so I bought a danfoss pack from Screwfix but the actuator is not the same as it’s HSA3
Are but will this still work I know HSA3 is for a 3 port Valve but I’ve only to 2 port valve
Many thanks
Nic
Reply to Danfoss Actuator help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone, my first post here so go easy on me... 😄 I have Danfoss HPA2 motorised valves fitted to my heating system and one of them is giving me problems again. Typical as its the same one I replaced in December 2022. The heating never came on today so I checked the valve and the lever on...
Hi I have a 4 zone / 7 loop UFH system. 2 zones (4 loops) always get hot when the system is on when the zone thermostats and actuators are off. The video posted shows when I turn on another zones the flow meters drop. (Kitchen prep and kitchen TV are the issue, two at either end of the...
1K
Hello. I've just replaced our old Potterton EP2 CH controller with a Drayton Wiser HubR (& peripherals). The old backing plate wasn't compatible with the new universal one, but the wiring was pretty close AFAICT (N, L, 1, 3 & 4 connected) .When I first powered it up but didn't have any TRVs...
Hi guys, I have a set up with rads upstairs and UFH downstairs. I have installed the manifold for the UFH along with 2x Honeywell 2port values, one near the manifold and the other on the radiator side. I will be using Nest 3rd gen thermostats to control both the upstairs radiators and...
2K
I have a Danfoss 2-port valve model HPA2 (which has suspect motor issue) I can get Honeywell 2-port valves & motors much cheaper & easier as local Trade place stocks Honeywell. Is there a direct equivalent Honeywell motor activator? ....... so I could just swap the synchronous motor over ? or...
