Discuss Danfoss Thermostat not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
G
greysoon
Hi, I recently replaced the battery in my Danfoss TP5000 Si thermostat and now the temperature's stuck at either 8 degrees or 15 degrees and it won't respond to me turning the temperature up or down, it's like all of the buttons have stopped responding. Any help and advice much appreciated!
perhaps you could try to take the batteries out for a longer time and afterwards resetting again. it might be an internal issue with the thermostat
Thanks for the suggestion, I'll give that a try
Just an update. Leaving batteries out for longer seemed like it had solved the problem but then the problems came back a few hours later.
Spent 40 minutes on hold to Danfoss customer "care" line, who told me to buy a new thermostat.
So I did. The new one's working fine. Problem sorted. Thanks for trying to help, though.
Reply to Danfoss Thermostat not working in the Plumbing Jobs | The Job-board area at PlumbersForums.net
