Discuss Desperately seeking a plumber for boiler - Wembley area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
When I turn on hot water tap, it doesn't always trigger the boiler, especially with the shower. As it normally works with the bathroom sink I turn that on to trigger boiler and then turn on the shower. Okay for us but when you have guests :(
Make and model of boiler ? is it a combi ? you will need a gas safe engineer to look at it call 0800 408 5577 Gas safe they will give you numbers of engineers local to you
Afternoon. I am in the Midlands so not in your area. But I am sure one of the boys/girls will be along shortly that can help you.
Make and model of boiler: Turbomax VUW 242E, 282E. Yes it is a combi. Thanks, I will call now.
Reply to Desperately seeking a plumber for boiler - Wembley area in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I am looking for a heating engineer to diagnose and resolve an issue with my Vaillant EcoTec 832 combi boiler. Job Location: Copeland Rd, London. Job Description: Problem: The boiler is not providing heating under normal conditions, although hot water supply is fine. Interestingly...
Hi All Bit of an urgent one being that time of year and can't get a plumber out until after xmas even on an emergency callout I have just tried to turn on my CH for the first time this year as I have a number of guests coming for xmas dinner but even after an hour all the rads are stone...
I have a problem with noise and vibrations from my shower when i first turn it on. The problem lasts for about 30 seconds after the shower is switched on before it stops. There is a sink nearby, sometimes if we switch that on slowly before turning on the shower then the shower doesn't make a...
H
Wishing everyone on tgmhis forum a very happy Christmas!! I am working on a combi boiler which has problem with heating only. Water is heating normally. Here are the symptoms 1. Signal from thermostat is not firing the boiler. It does not make any sound when heating is on from thermostat. 2...
The Water Board have just replaced the main water supply to our property. We have a ground floor combi boiler. The central heating system for the whole house is working as normal. Hot water is working as normal on the ground floor. However, there is no hot water to the first floor bathroom. This...
